Electrical Problem
Electrical Problem
We got our first real snow in Chicago on Sunday. I took the Evo out and I turned on the rear wiper to get the window clean. I turned it off after 2-3 minutes as it's not needed when the car is moving (rear window stays dry).
The window got wet again when I stopped at at light. I turned on the wiper and it made one full sweep and then 1/3 of a sweep. The wiper stopped in the middle of the window. I had to keep turning the switch on and off to get it to make enough sweeps to rest flat the way it's supposed to.
I went to the grocery store and I noticed that my lights were on when I returned to the car. The lights never stayed on before. I could leave the lights in the "on" position, but they'd always turn off when I removed the key from the ignition and opened the door. Now my lights stay on unless I turn them off myself.
Both of these problems began yesterday. Is it something simple like a fuse or do I need to visit the stealer? Has this happened to you?
Stay Tuned
I described the problem to the service guy at my dealer. My rear wiper doesn't work, my driver's side tail light is out, the driver's side rear doorlock does not work and my headlights don't turn off when I leave the car. He said it's a bad switch and I will be bringing it in on Tuesday.
