(not idling properly need HELP!!!) have power fc
(not idling properly need HELP!!!) have power fc and on cold start i have problems, have to play with the pedal to get it started then revs up to 3g. when worm at the lights it hunts up to 1500 then to 900. sametimes i can get it to stop if i take my foot off the brack or tap the acc.
with STOCK ECU NO Problems. have done a idle tune properly still the same (hard to do at start have to play with acc). its been tuned 2 times, told tuner and still the same.
evo 7
cams 272
20g 11.5t
255 fuel
arp head studs + gaskets
thanks
evo 7
cams 272
20g 11.5t
255 fuel
thanks
here is how I solved my problem: (my car was so bad that it took 3 attempts to start and would not stay running at stop signs) I had to feather the throttle a lot.
replaced the air idler servo
removed and cleaned the EGR valve
adjusted the idle screw
removed & cleaned the throttle body
checked all vacuum hoses
My car now idles perfect.......
dgkiller
Sep 9, 2015 09:07 AM
