Who has a FP 71 HTA set-up?
Old Oct 16, 2011, 06:30 PM
jrlewis0550's Avatar
Well I made 360hp and like 358tq at 22 psi. Yeah I know 22 psi is low but my waste gate won't hold anymore. So next step is to get a stiffer spring for my waste gate.
Old Oct 17, 2011, 05:52 AM
BigT's Avatar
Seems like this HTA 71 is very promising.
Old Oct 17, 2011, 10:11 AM
211Ratsbud's Avatar
I have one thread started in dyno forum.
Old Oct 18, 2011, 09:37 PM
jnut24's Avatar
nice numbers!
Old Sep 27, 2012, 01:03 AM
hermin0000's Avatar
So whats the deal, results, feed back, ANYTHING? I can pick one up fully loaded for less than $1,500.
Or should I go green for over $1900 fully loaded?
Worth saving 400 dollars, stress on the engine, and turbo no turbo lag??
Old Sep 27, 2012, 01:55 AM
evo8426's Avatar
What is your hp goal?
Old Sep 27, 2012, 01:06 PM
hermin0000's Avatar
400 + whp / less than 380tq. mustang dyno on e85
I'm wondering what people got out of there 71 hta just the same as the OP.
I guess I should have just bumped the thread.
Old Sep 27, 2012, 02:01 PM
ToddRhodes's Avatar
If it's a $400 difference, go Green IMO. Being that I have a IX, mine was only $650 to upgrade from FP but I did add the 84mm cover and just now ordered up an 18 psi wga for it since my stock wga seems to be dead at 24 psi, she gots' no more to give cap'n!
Anyway, in a word - OMGIluvIt. Seriously, it feels like a stock turbo, even with an S1 intake/S2 exhaust cam combo. I have no idea where I see full boost, but it's early and often. Running about 24 psi, tapering to 21 with the mods in my sig. VD reports 387 awhp. It feels stronger everywhere over the stock IX turbo. It's not a gigantic difference, but it is definitely noticeable. But, if I had to pay $1500 for it and could get a Green for a few hundred more? That's a no-brainer IMO. The major selling point of the HTA71 is the value you get for $650...
Old Oct 13, 2012, 07:27 PM
hermin0000's Avatar
Thanks for your feedback. I bought a fully functioanl 9 turbo for $200 and sent it into fp for the hta71/84mm comp cover upgrade. Were those results on e85 or pump? Also, Whatevs the turn around rate for your turbo?
Old Oct 13, 2012, 07:30 PM
ToddRhodes's Avatar
I run pump gas only (93). Turnaround was about 10 days if I remember right. Did you get the upgraded compressor cover? I would also recommend a better wastegate gate since it's so cheap when you're doing the upgrade...
Todd
Old Oct 13, 2012, 07:38 PM
hermin0000's Avatar
Todd
Ten business days after it arrived? ahhhh that's sooooo looonnggg
Yes I am getting an upgraded compressor cover and 18 psi wga. I'm going to just set high preload because I will be running e85 (can't justify $5/gal for california 91 pump anymore).
Old Oct 13, 2012, 08:52 PM
sparky's Avatar
....Yes I am getting an upgraded compressor cover and 18 psi wga. I'm going to just set high preload because I will be running e85....
Since you will be running over 25 PSI peak boost level and as you stated over 24 PSI of spring pressure, then I would suggest the 25# actuator. I realize that I originally recommended the 18# unit but you would have to cut the actuator rod to run that high of a preload level. You are better off getting the 25# WGA right off the bat. Ratsbud has a 71 HTA and he is having a tough time setting spring pressure above 16# on his FP 18# WGA.
Old Oct 13, 2012, 09:05 PM
hermin0000's Avatar
Gotcha. The only thing is that the tuner said 23-27 psi on e85. But on pump 91 it could be as low as 22-23. So would you still suggest running the 25psi actuator with no pre-load?
Old Oct 13, 2012, 09:06 PM
djdnav's Avatar
Originally Posted by 05blue8
I installed one of these on my friend's car. His results weren't that great over an evo 9...lemme find his info real quick
He was at 350/360 on an Evo 8 RS at 30 psi on pump (made 30psi at 3600), HKS272 cams, ported hotside/o2 housing, IC, exhaust, intake. His car wouldn't take any timing or boost so something was going on. It wouldn't run better than the old Evo 9 turbo he had swapped it out for unfortunately. Probably not a good car to run a comparison against but you asked
Thats horrible. i made more than that with smaller cams on a 9 turbo!
Old Oct 13, 2012, 09:45 PM
sparky's Avatar
...The only thing is that the tuner said 23-27 psi on e85. But on pump 91 it could be as low as 22-23. So would you still suggest running the 25psi actuator with no pre-load?
The 25 pounder is the one for you. The advertised 25# claim is a bit misleading. Actually, you can run them as low as 18-20# with no preload. Meaning base spring pressure is about 18# and not the FP advertised 25#. So rest easy you will be adjusting preload higher than the 18# base even with the so-called 25# unit.
Since you'll have dual maps each with a different peak boost level, you'll have to set WG spring pressure in the the 21-22 PSI taking into account the projected 23 PSI of the 91 octane tune. This preload level should be fine for your E-85 tune as well.
If you get the 18# unit you will end up having to cut about a 1/4" off the end of the rod to get it up to 21 PSI of spring pressure. If you don't mind tinkering and modifying it, then you can get the 18# unit. Just be forewarned that you'll have to chop it.
Spec Ops', Mikey runs an 18# unit on his high boost FP Black, 2.4LR setup. But I am pretty sure that he has had to take a hacksaw to the actuator rod...severe trimming.
Quick Reply: Who has a FP 71 HTA set-up?
