evo engine noise
evo engine noise
i got a weird engine noise on my evo 9 ,also when you go to press the pedal for the clutch you feel a vibration too.
here is a vid of what it sounds like
http://www.youtube.com/watch?v=UpfE8...eature=related
I can't make out anything out of the ordinary in that video. You may want to check this thread. It's a sticky in the Evo Turbo/Drivetrain Section
https://www.evolutionm.net/forums/ev...elt-video.html
Anything done to the car recently??
Honestly dude I can't tell anything from that video. It sounds like a Powerstroke Diesel under the hood.
If it sounds like a pulley/bearing rattle, I'd start by holding a long screwdriver, point-end onto the accessories and see if I could feel a vibration. You want to be careful here. Don't stick it into anything spinning, and definitely don't drop it.
Otherwise, I'd probably pull the serpentine belt and spin the pulleys while looking for noise. Don't feel bad though, I have a noise that I'm trying to identify at 3800 rpm while driving. Good luck.
jxp90
Mar 23, 2017 01:25 PM
OG
12
Apr 19, 2013 05:39 PM
