electrical/stock gauge cluster problem please help! Evo 8
ok i finally got my LY EVO8 back from the shop and on the way back home i noticed a lot of wires had been moved around and my gauge cluster does not light up nor my aem air fuel gauge nor the CD player... it seems just like a tiny wiring problem but wiring is not my thing if you guys could help it would be greatly appreciated! i kinda just need to know what fuse/wire to tamper with to get those to be up and running again and btw it sucks not seeing you gauge cluster at night lol thanks fellas!
Second thing is, after they telly you some nonsense about them not touching anything like that is to check to make sure all the connections are correct.
You can check in your manual for the fuses... I'm not sure if the interior lights are all on the same fuse like that. The box is located right by your left knee when driving though... you can check those fuses.
05RalliartJake
Mar 22, 2013 07:23 PM
Avirex
16
Aug 9, 2011 06:24 AM
