Turquoise grease leaking
I'd bet that its axle grease. That's certainly grease, and it will get more green as it collects more dirt.
Time to feel up some boots IMO. lol.
That's from this link btw: http://mkrd.info/how-to-s/car-cv-axl...placement.html
It's an article detailing CV and axle repair. I found it using GIS and typing "Axle Grease" in case you need more examples.
Hope that helped a bit.
I'd say black axle grease is the most common but I've seen blue like the pic and also light yellow. BTW, when a boot starts leaking it doesn't just drop grease on the ground, it flings it all over the place. So, it should be easy to tell if that is your problem.
It sounds like it must be the inner boot. This is simple to repair - if you don't mind playing in grease for a couple of hours. However, you need to do it right away. Drive enough to get dirt in the boot and the axle is toast. Most of the work involves getting the axle off of the car.
BigDee
22
Jun 27, 2012 08:10 AM
kt411gcn
Apr 17, 2012 12:13 PM
