Winter storage. To jack or not to jack
Old Oct 20, 2011, 06:35 PM
zenoise's Avatar
Ive searched and only come up with terrible Mopar sights for answers but here I go.
Im looking to store my car for the winter (hopefully only 5 months) and I have the Gf210 tanabes that so many have for their evo. My question is if it is hard on the suspension to put the car on four jacks leaving the struts dangling with or without the wheels but prolly with out or am i better leaving it on the concrete floor pushing it back and forth now and then?
Any help would be *****.
Thanx
Old Oct 20, 2011, 07:17 PM
killerpenguin21's Avatar
ive done it both ways, never had a problem with either. if your going to leave it on the ground tho, i would suggest having a set of ****ty tires you dont care about in case they flat spot.
ive also seen guys have shock seals die when fully extended from being up on stands.
Old Oct 21, 2011, 12:46 AM
slads's Avatar
Leave it on the ground. I always do with a set of winters on. That way if you get the urge to do some awd you're ready to go. Only drive mine once or twice a winter and never regret it. It does help that I have a lift and a floor drain so I can wash the entire underbody when I get back in from the snow.
Old Oct 21, 2011, 07:22 AM
1UpMoto's Avatar
you can put the jack stands under the control arms so the suspension stays compressed.
Old Oct 21, 2011, 07:40 AM
newbieEVO8's Avatar
What he said or just jack it up enough to take the majority of the weight of the car off of your tires.
Old Oct 21, 2011, 03:54 PM
wht95scort's Avatar
Or if you want to leave it on the ground just over inflate your tires to around 50psi to avoid getting flat spots
Old Oct 21, 2011, 04:47 PM
sujinX's Avatar
why buy an evo to store it for the winter? just drive it.
Old Oct 21, 2011, 04:58 PM
whitebreadd's Avatar
**** that, why ruin a nice car in the winter. The salt up here in michigan just plain wrecks ****.
Old Oct 21, 2011, 05:44 PM
Tpatterson's Avatar
When I stored my cobalt last year, all I did was put fuel stabilizer in the tank, pump the tires up to 45 psi, and put the battery on a trickle charger. Had no problems when I started it up 6 months later.
Has anyone tried vehicle dollies? I was considering buying 4 of them to put my car on so I could easily leave it sit all winter and be able to move it around the garage. I wasn't sure how they would hold the weight long term.
Old Oct 21, 2011, 05:54 PM
awdturbo8's Avatar
I did wheel dollies from harbor freight tools. They work great. Car sat on them for 7 months without an issue.
Old Oct 21, 2011, 05:57 PM
1UpMoto's Avatar
thats why you wash your car alot.
Old Oct 21, 2011, 06:04 PM
GTijoejoe's Avatar
If I were to do it, I would jack it under the FR and RR subframes, and take the wheels off.
Old Oct 21, 2011, 07:57 PM
hereitcomes's Avatar
Modern DOT tires for the past 15 years won't develop flat spots. They will dry rot before anything else. I store my Talon every winter, with no pushing it around. As soon as the car starts moving the tire resumes its normal shape. But however, my sidewalls are garbage due to a leaky tire that was flat for 5 months.
Old Oct 22, 2011, 03:23 AM
njboy's Avatar
As soon as the salt goes down I take my IX off the road too. Shame but I want to keep my car nice and it's easier to work on with far less corrosion. I just wash her and park it in the garage. Never had a problem with the tires.
Old Oct 22, 2011, 04:29 AM
FJF
FJF's Avatar
Why didn't any of us think of that?
Same here. I fill the tank and park the sucker. As soon as the salt is washed off the ground, it comes back out.
Quick Reply: Winter storage. To jack or not to jack
