Any yellow Evo running catless?
I'm curious if there're any yellow Evos running without the cat. I intend to decat my yellow car, but am very concerned about the effects the decatted fumes may have on the PAINT of the car.
I used to have a decatted white car whose rear end turned yellowish almost instantly. And after a while the discoloration couldn't be cleaned off no matter how hard you rub/wax/polish.
So... help please, thanks!
The only other EVO I have seen that was not at a dealership had exhaust with no CAT and was yellow. For your luck the rear bumper looked ok. Although I would reccommend sometype of CF trim around the exhaust. I have seen this somewhere. Also if the exhaust pipe was extended maybe an inch or 2 out from the car I don't see how this would be an issue.
I have the HKS 30th exhaust with no cat on my yellow EVO and I am getting stains on the bumper. You can't avoid it..... I had the same problem with my white MR2 turbo. I've always been able to take it off. You just have to remember to buff/polish it off everytime you wash the car.
I just can't remember who on the board was talking about making an exhaust heat shield.
Oh yikes!
Thanks for the heads-up. Anybody else has "stains"?
In white color I know it'd be very obvious, but I was hoping in yellow it won't be.
Sigh... maybe I may just splurge on a high-flow cat.
I get stains no matter what.. Just like what Option2 said, you gotta polish that spot everytime you wash the car.. Then it'll always come off... Takes an extra 5 minutes to do it...
my car has had the exhaust since it hit 800 miles that is with the cat delete pipe as well and now it has almost 7000 miles and it really has never had a stain like i said but i do not have to wash my car all the time, and i take it to 7000rpm daily
Thanks for all the responses!
Funny huh, it seems different parts of America produce different kinds of stains (or lack thereorf)
Anyway, I bit the temptation: decatted the car yesterday. IMMEDIATELY (i.e. today) I noticed a 'darker' than usual blackish stain on the bumper just above the exhaust opening.
A quick polish removed it
ASIDE: is it just me or cat-delete doesn't do much in terms of power-up? The rest of my exhaust is stock, and I noticed only a slightly stronger pull; quick glance at boost gauge confirmed boost has risen about 0.05 - 0.10bar across the RPM range.
My previous STi was noticably MUCH faster/more responsive after a catless downpipe upgrade.
It's an HKS Kansai product
http://www.kansaiss.co.jp/parts/kam025.htm
I personally don't quite like it, it brings too much attention to the exhaust.
BTW guys just for clarification, when I asked if your bumper/rear end has stains/discoloration, I do mean the "bumper/rear end".
For instance, my previous white car was discolored on the bumper area above the exhaust opening AND the rear-facing trunk-lid; anyone can easily see it was of different color than the rest of the car.
I wasn't referring to the "arch opening" directly above the exhaust tip.
Hmmm well in that case, its all over the back, not just by the exhuast opening, thats the only "stained" part, the rest washes off at every carwash.
Mostly on the rear is little splatter marks, like after I let it warm up, then step on it, (hate this especially after I wash it) there will be all these little bits of splatter. I will take a picture sometime.
