Hobbs Switch Schematic Help
I had to make this schematic, because I've searched for days and found nothing. Here is the picture
![](http://img706.imageshack.us/img706/9890/hobbsswitchschematicjpg.jpg)
Uploaded with ImageShack.us
I'm sorry, as I know it's hard to read (made on MS Paint).
Nevertheless, my confusion is how i tap the lines on the full blown setup. In order to control one of the pumps, I think I: give power to the hobbs switch, ground, and psi pressure, and then combine these lines with the power/ground lines from the full blown setup. Does the picture look about right?
nooo
from the second fuel pump there is two wires that come out
-ground and 12v switched
--ground the black
--run the red 12v wire all the way to the hobbs switch (that will trigger it to get voltage once the boost level is meet
at the hobbs switch there are two pins
- run the red 12v wire from the fuel pump to one of the pins (doesnt matter which)
-the other pin on the hobbs switch goes directly to a positive battery terminal (with a 20a inline fuse)
-then the nipple just goes to any boost line from the manifold (ppl normally tap the bov line)
--ground the black
Headgames Motorworks
Feb 1, 2014 05:37 PM
mrwickd123
Aug 15, 2013 12:21 AM
XTR Performance
EvoX 'For Sale' Exterior Styling
20
Nov 24, 2012 11:12 AM
John@MooreAuto
35
Mar 12, 2012 08:10 AM
