Volts low
Generally mini batteries die quicker and don't hold much voltage opposed to the OEM size ones. Also if you live in a cold climate, you'll have issues starting your car with a mini battery in sub zero weather. I would check the connections, but consider going to the OEM route. You give it up for the short route UICP for performance, but it's your decision.
