Alternator Removal
Alternator Removal
My alternator is taking a dump on me and is now down. Im gonna removal and put a new one in obviously. For anyone that has done this. Can you speak up and tell me what you put in oem or aftermarket(autozone) And how hard was it.? thanks
I did mine around 1 1/2 months ago, i bought a alternator from STM. The way me and my friend did it was going through the passenger wheel. took us around 1 hour and it was our first time, we also used a car lift :P But we really dident need to use it.
It's a mini project I'll tell you that. You need to remove the top bolt from up top and if you remove the axle you should be able to come out the bottom. Pulling the axle isn't that hard.
the evo service manual says to take it out from the top but you'll have to jack the engine up a bit to get it out. the only other option is to take the passenger axel and dp out, which is what i did.
by the way, popping the axel out is easier than it sounds. that harder part of this whole thing for me was the underbody panel. those dam plastic clips are a pain in the ****.
