Best tool kit
http://www.amazon.com/Crescent-CTK17...1519787&sr=8-1
To OP, I keep this in the trunk of the Evo in case anything happens anywhere. It's not that expensive and pretty much has everything you'd need for small jobs. Just for the occasional small job here and there, the quality of the tools in this set is more than good enough.
Edit: Sears Black Friday tool sale:
http://toolguyd.com/2011/11/craftsma...11-tool-deals/
This site regularly features the better tool deals.
I made my own with a small Husky tool bag from Home depot.
Went to Sears and Harbor Freight to fill it up.
I bought a set of shallow 12pt 1/4" drive sockets, 1/4"drive ratchet, deep well 12pt 3/8"drive sockets, 3/8"drive ratchet, 1/4 to 3/8 (vise versa) adapters, metric combination wrench set (stubby 8-19mm), small hammer, heel bar, chisel/punch, small vise grips, adjustable pliers, screwdrivers, picks, wire crimpers, crescent wrench, cheap Harbor Freight multimeter, 12 & 18 guage wiring, assorted electrical connectors, mini ATM fuses, electrical/masking tape, tire repairis kit, zip ties, loctite, epoxy, and a flashlight.
It is great to have when you are going way out if town. If I had to guess I spent about $125 on all of it....cheaper than one tow truck trip.
As for brands, for this type of kit, some decent brands to consider:
1) Husky. Cheap. Available @ home depot. Acceptable quality. Readily replacable.
2) Proxxon. Inexpensive, good ergos, complete sets @ amazon.com. 3/8 socket sets up to 24mm.
3) Facom. On sale, cheapest of the higher end stuff. search online.
As for how to go about it, follow FJF's link above for research. IMO, A kit that is good enough to use for routine maintenance, but won't make you cry if it gets nicked, is a good balance.
I recently did this exercise
This is what I cam up with, although not for EVO specifically.
It took about $100-150 bucks all in.
-Sockets 3/8- Facom to 17mm ($55, demo kit w/case), +19mm Stanely USA old stock, $2 at Ace [Alt, consider: or Proxxon 3/8 to 24 ($80)]
-Wrenches, combo open - Stanley to 17-22MM $30. New old stock, USA @ sale bin at Ace.
-Wrenches, offset closed - Husky to 8-19MM $12. includes tool roll.
-Screwdrivers, Hex, 6 in adj, vice grips - Misc. on sale. ($20-30)
-All fits in a 12 inch soft bag - Craftsman, $10 (agree w/ posters above soft is way to go)
For real work, ratcheting wrenches are awesome, but consider $$ and if you want to leave more than one or two in the car. A single snap-on is like $30, and while Gearwrench are cheaper, are still not cheap.
The bigger box didnt move around alot unless I was having too much fun (weight plus large flat area on bottom). With the spare tire out and the board gone, it never moves around anymore, but does not sit flat.
I keep no tools in my Evo, when I had mydsm it was another story. The evos reliability has been great for me so far (although mine is one of the very few stock ones remaining)
Here is a good kit that doesn't take up much space and made in
http://www.amazon.com/Pratt-Read-800...100288&sr=1-13
The Pratt-Read 80010 16 Piece SAE Nut Driver & Screwdriver Set is a great example of a Industrial quality hand tool engineered for even the most demanding of users. The PRQ Quick driver system is a convenient, space saving, portable toolbox of interchangeable blades, designed for any technician, serviceman, or home hobbyist.
The PRQ handle is made of cellulose acetate, a renewable natural resource derived from wood pulp. Cellulose Acetate is a rugged impact and chemical resistant material. It is not based from a petroleum-based product. The locking chunk securely holds all the blades and allows the user to quickly change the blades. The PRQ handle is ergonomic and has a accurately sized 4 flute handle design for comfort and maximum turning power.
Pratt-read's line of interchangeable nut drivers are made from top grade molybdenum alloy steel. Each blade is cold-formed for tight tolerances and sure fastener fit, then heat-treated for maximum strength and durability and are made from custom zinc plating for corrosion resistance.
Screwdrivers are made from nickle-chromium-molybdenum alloy steel and heat treated for maximum strength and durability and, thanks to it's custom zinc plates, are resistant to corrosion. Slotted tips are forged to tight tolerances for a sure fastener fit. Phillips tips are precision machined for tight tolerances and a tight fit.
