what aftermarket lugnuts fit oem wheels
hi every1
looking for a set of lugnuts that fit oem wheels and has a special lock to unbolt them. this morning someone loosen my lugs and i didnt know till i drove on the highway. trying to avoid hater trying to kill me lol.
thanks
thanks
EvoM Community Team
So, depending on the seat your wheels use you may be looking at either conical/acorn, ball or the less common mag seat style.
Once you've got that figured out, you need to check the studs you are using.
If you're using OEM studs, you will want M12x1.5tp nuts. If you are using extended studs, you will want to get the appropriate nuts that are either longer or open ended to accommodate the length of the aftermarket studs.
So, if you can find a company that makes the lock & key nuts that will fit the size and seat you need, you're golden.
Sorry to bump an old thread but I've been trying to find the answer to this question since I'm about paint my stock wheels. I found these on Amazon:
They look like they'll work. What do you guys think? Anyone have any experience with these?
Amazon.com: 20 Locks + 1 Key Set 12x1.5 MAG OEM Style Open End Lug Nuts Toyota Solara Camry Avalon Lexus NEON CHROME Color A107 MAG NEON 12x1.5: Automotive
jpsEVO
For Sale - Wheels / Tires
Jun 8, 2014 06:01 PM
marcusE
Aug 25, 2011 06:54 AM
aftermarket, afternerket, evo, evolution, fit, lancer, lug, lugnuts, lugs, nuts, oem, replacement, rims, stock, wheels
