Barometric pressure signal sensor
Hi guys.. I recently bought 10 years old evo 7. Did computer check and found out that the barometric pressure sensor signal was not working. What are the sign if the barometric is not working? Previously when i drove my car around 50km, the oil pressure will drop and there would be no boost at all. I need to restart the car to have the power back. Please help me. I just use the car for 2 months only
You've got a lot of things going on here but I don't see any connections.
The oil pressure light coming on means either you have a bad sender or the oil pressure is actually low. Low oil pressure does not affect boost. I'd suggest replacing the sender and if that doesn't fix it then attach an accurate gauge to where the sender screws in to and obtain a reading. If lower than about 4 psi at hot idle you need an overhaul.
The barometric pressure sensor is used by the ECU as part of determining that amount of fuel to inject. I've never had this problem so I don't know the symptoms. It could be the sensor itself or bad wiring.
Having to restart the car to get it working again? That sounds strange.
han74j
Sep 12, 2014 05:54 PM
