voltage drop = idle drop?
Just wondering if this happens to anyone else?
The "whine" that my walbro makes changes when the voltage drops. Usually this is if I press two of the window buttons at the same time (like if I try to roll up the passenger and driver window at the same time) My voltage drops from 14 to about 12 and the idle also drops from about 1100-1000 and oil pressure drops a little bit too. Is it normal for idle to drop when the voltage drops?
BTW I have no sound system or anything... I can take a video of it if that helps. Just wanna see if it's normal, or if it's injector scaling related, fuel pump problem, battery related, or alternator problem
