Tcase death whine, is it done?
Old Dec 23, 2011 | 08:59 PM
Don Q's Avatar
Hi guys,
A few weeks ago my car started leaking from the tcase, I towed it to the shop and they got it fixed. A week later(today) I heard the death whine . I was wondering if it's done and needs a rebuild/replacement or if there is any other possibility like "low fluid?"
Thanks in advance
Old Dec 23, 2011 | 09:18 PM
impact blue's Avatar
Originally Posted by Don Q
Hi guys,
Thanks in advance
I think your transfercase was done when it had that leak which casued alot of damnage. Even though they fixed the seal from whereever it leaked from the damage still has been done. I strongly recommend you take it to a trusted shop that works and specializes on the car and have it checked be prepared though.
Old Dec 23, 2011 | 09:20 PM
marcusE's Avatar
Search dude...
change the fluid and make sure its filled properly if it still whines then obviously you need to have it rebuilt.
Old Dec 24, 2011 | 11:04 AM
Don Q's Avatar
Thanks for the quick responses... I'll call the shop first thing on monday, I don't have the jacks to keep the car level to check the fluid :s.
Old Dec 24, 2011 | 01:51 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
The transfer case in the CT9A is a fairly fragile piece of equipment if not maintained properly. You can't run it with low fluid and you can't run it with anything other than the OEM fluid.
If you're starting to hear the, 'death whine' as some people call it chances are it might be done...
Old Dec 24, 2011 | 03:50 PM
Don Q's Avatar
That sucks . I was wondering how much life is left on it? I have read on some other threads that they have hold up to 25-30K miles after they started with the death whine... Is this true?
Old Dec 24, 2011 | 04:19 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Do a fluid flush and top it off. Run it for a while and see how it sounds. If it holds up for another X0,000 miles and doesn't damage anything, then good for you.
I don't have any experience running a noisy transfer case, so I cannot recommend either way. I don't know what other parts of the drivetrain might be damaged by running a failing transfer case. You may want to get more opinions or do some searching on EvoM and see what you find.
Good luck.
Old Dec 24, 2011 | 06:11 PM
I strongly recommend that you do not drive that car at all until you get it to the shop. Do not drive it there take it to a shop that knows about evo's and have it rebuilt. The more you drive on it the more you are just messing up your drive-train. Very delicate piece of equipment driving on it is more than just a deathwine. Your pockets will be doin the deathwine with even more money out of your pocket after it tears up more stuff in there.
Old Dec 25, 2011 | 12:08 PM
jc05's Avatar
Get a new tcase
Old Dec 25, 2011 | 12:20 PM
gsr0801's Avatar
My t-case has been whining for about two years now on a DD car and still going. The whine does get louder when the fluid is low though.I suggest rebuild it if you can. I'm just riding mine out till it gives out because I have another one sitting around.
Old Jan 9, 2012 | 04:28 PM
stayabovethelaw's Avatar
mine has been making noise like 3 years also just waiting to see what happeneds...
Old Jan 9, 2012 | 05:33 PM
Ramen_Noodle's Avatar
Depending on cost, and I know this is a long shot, but I wonder how much a shop would charge you to crack it open and have a look? If it's done for then you already have it off of the vehicle and can ship to Shep, TRE, or Buschur OR transport to a local repair shop, no?
Jonno99
Aug 15, 2016 11:34 PM
Migsubishi
For Sale - Part Outs
Apr 22, 2016 10:32 PM
Bob Doe
Jan 25, 2016 04:09 AM
booosted
Sep 2, 2015 06:38 AM
BaLListic_EVO
11
Apr 13, 2008 06:21 PM
Quick Reply: Tcase death whine, is it done?
