clutch pedal problem
Old Jan 4, 2012 | 09:10 AM
Johnnyb93's Avatar
One day I was driving my evo back home and I got on the gas and shifted alittle to quick, so my clutch pedal got stuck to the floor. I played with it alittle and it budged back to normal. After that incident, my clutch pedal has been vibrating when pushed in slightly but when pushed in all the way it did not. Also there was alot of shatter when I was starting off at 1st gear. Now, today my clutch pedal went to the floor and stayed there like a rock. The car still can go into all the gears without using the clutch. And on a side note, I just replaced my clutch and flywheel about a month ago. Any inputs?
Old Jan 4, 2012 | 09:17 AM
limp_noodle's Avatar
try bleeding the clutch. I had a similar problem on my old car. I bled the clutch, but I also changed the line to a SS one.
Old Jan 4, 2012 | 09:46 AM
hiner005's Avatar
I agree. You should bleed the clutch. Dd you replace your TOB? That may also be the reason.
Old Jan 4, 2012 | 03:13 PM
bigben's Avatar
Yes, pull out the clutch inspection plug on the tranny and look at the TOB. If it is wobbling then the vibrations will follow straight back to the pedal. It sounds like the TOB popped out of the pressure plate momentarily (if the pedal went to the floor).
