Dynapak vs Dynojet dynos...
I have been dynoed on Pruvens AWD Dyno at 265whp. If I were yo go on an AWD Dynapak dyno (Agile Performance) should the results be the same, higer or lower?
Originally posted by Alfriedesq
depends on what settings they load into the dyno pak - a lot of variables can be adjusted
Well there is an AWD dyno 5 hours from me or an AWD Dynapak 1 hour from me. I made the 5 hour trip once to get the Dynoflash, I just don't see any reason to go there for some dyno time...and there are no Duno dynamics dynos around here.
If someone knows of an AWD Dynojet around the southern PA/Central-Northern MD region...feel free to let me know
Correct me if i'm wrong, but doesn't a dynapack dyno require you to take the wheels off so the machines can connect directly to the hubs? How would that produce lower numbers when you're taking out all that rotational mass from the wheel/tire combo?
dynoes are relative only to themselves quite frankly.......not even aross brands, but literally to how a given car puts down power on that given dyno.
Comapring it to anotehr dyno in another state (even by the same manufacturer) is nearly impossible to do.
A dyno can be manipulated in any number of ways....regardless of the brand
The Dynapak read the exact numbers on Dan at Machv's bone stock EVO as our 2wd Dynojet did on our bone stock EVO.
Dynojet's rock. How much horsepower does it take to propel a 3300 pound car to 11.65 at 117.88 mph? According to a quick slide rule thing I have here it takes 425 hp. That is flywheel. If you calculate a 15% loss through the front wheels that makes 362 hp. We made 380 whp and ran the 11.65. How far off is the Dynojet?
The MPH on our Conquest is low from an inefficient torque converter that we use. Let's consider though that to run 8.71 with it that this same chart says it would need 750 flywheel hp. Take the same 15% and that leaves 638 wheel hp.
No matter how you look at it all the dyno's measure different and are good for only one thing, that is tuning.
David Buschur
www.buschurracing.com
David Buschur
Originally Posted by limey
....It is ONLY in america that chassis/whp #'s are considerably higher than the rest of the world because of dynojet setting the president way back when and then continuing to be established here...
There's an excellent article in the Aug '04 issue of SCC about this exact thing. They used a Ford ranger to test and 6 different dynos, here's the results:
Dynapack @ A'PEXi - 157hp/179lb-ft
Dynamic Test Sytems @ XS Engineering - 155hp/181lb-ft
Maha @ AMS - 105hp/120lb-ft
Dyno Dynamics @ Vishnu - 102hp/142lb-ft
Dynojet @ HKS - 152hp/193lb-ft
Dynojet @ K&N - 156hp/196lb-ft
Take from that what you will, I copied that right off the graph. I was a Ranger with a 4.0L, and they used 2wd and 4wd dynos.
personally tuning on a dynojet is not the greatest.. loading the car up with a eddy current retarder is the way to go. (or a water brake on a engine dyno) Dynojets read high because once the car has the rollers at speed theres not as much resistence holding them back. As if to say your dynoing your car going "downhill"
I perfer a Superflow/Mustang/dyno dynamics/dynapack for tuning and dynojet #'s for show
good luck!
good luck!
