bleeding air from the diff
Old Jan 5, 2012 | 05:36 PM
ahmed moustafa's Avatar
good morning i have evo 9 and i want to ask about how to bleed air from the diffrential system and what is the ayc or acd i dont know exactly what is the correct name of it ,
thanks
Old Jan 5, 2012 | 06:33 PM
73DatsunZ's Avatar
There are several threads on here that tell you how to do it properly. Use google as well there are several threads with pictures. Its typically a 2 person job, and you will need the OEM fluid from the Dealer to flush it properly.
Old Jan 5, 2012 | 07:21 PM
bcrance13's Avatar
Have a friend get under the car near the t case bleed screw for the ACD system. Insert your key and turn the car to the on position. Press your gas pedal to the floor till you hear the ACD system pump kick on and turn off. Repeat this process until you have satisfied your bleeding desires. Use a good ATF for the reservoir fill.
Old Jan 6, 2012 | 01:25 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Transfercase (LSD):*
The transfer case holds .58 Quarts.*
Mitsubishi OEM GL5 LSD Gear Oil Diaqueen Part #3775610 (http://www.mitsubishiparts.net/catal...ion=575#1348)* $38.49 1gl
DIY:* http://www.evomoto.com/tech_articles..._article_id=25
Rear Diff:*
The rear differential holds less than 1 Quart.*
Redline 80W140 GL-5 Gear Oil. (http://fluidmotorunion.rpmware.com/r.../i-148659.aspx) $10.87 1qt
DIY:* https://www.evolutionm.net/forums/ev...id-change.html
Transmission (5 Speed):*
The transmission holds 2.9 Quarts.*
Redline MT-85 (http://fluidmotorunion.rpmware.com/r.../i-395005.aspx) $10.98 1qt
DIY:* http://www.evomoto.com/tech_articles..._article_id=26
Old Jan 7, 2012 | 09:37 AM
73DatsunZ's Avatar
I think the poster was referring to the ATF red fluid you have to use to bleed the ACD with.
hype original
Lancer How Tos / Installations
Jul 19, 2017 06:53 PM
TeamEmperor-
Jan 31, 2017 10:02 PM
NewEvolutionIX
13
Aug 26, 2016 05:41 PM
vipevo9
Aug 25, 2016 01:36 PM
Thomar
Feb 10, 2013 03:18 PM
Quick Reply: bleeding air from the diff
