forge DV question
forge DV question
I have a forge black DV. When im driving at low rpm I can hear a slight whistle that goes up and down with rpm, however after about 3 rpm the whistle goes away ....it sounds like the bov.
My forge has the red spring and is put in backwards( suppose to hold better). Anyone had trouble with this bov, and how can I test it. I can not here it leak on a boost test
Yep had many turboed cars...it is a whistle....also if I hold the car around 8-10 psi while accelerating I can hear what sound lime air coming from my intake as if it was a bov that is constantly blowing air .....which is why I wanna know about the forge
What model is the BOV? I have the adjustable top Forge myself as have had no problems, do you have the "stock replacement" type?
Also, I have seen people install BOV's backwards, it does now work from anything I've seen personally. As for the spring.. I feel like if it worked "better" backwards, Forge would tell you.
Steve-
Steve-
