Motorend Magazine: EVO8 RS vs. EVO 8 braking distances
Originally posted by metaphysical
ABS doesen't stop quicker. In most cases it actually increases the stopping distances.
Most drivers cant threshold brake effectively enough to equal ABS.
Just my .02
Yeah, I'd like to know if ABS can be added to the RS as well...any idea of cost?
I don't think previous RS versions came with Brembos, but this might just be a US market exception...kinda like the "Urban Jungle" package.
A little off topic (sorry), does anyone know how easy it is to add HID's from the regular 8 to the RS? I've heard $800...but is it just a simple swap? Is new wiring, etc. required?
Originally posted by Lan Evo
Correct me if I am wrong. Based on my understanding, RS model doesn't come with Brembo. At least for EVO I - VI, that's the case. Since you're going to swap them out for racing parts anyway....
These days - forget it. The current systems are far superior to what any driver can do, even professional. The amount of times ABS pulsates now and the wheel independence they have is just amazing. You can simply stomp on the brakes and let the ABS take it down a notch if needed. And you can also be avoiding things or turning at the same time.
However, as stated already, the ABS has not yet evolved enough to be better in dirt, snow and gravel. Maybe one day it will sense what kind of surface the car is running on and adjust ABS logic - but this is not yet the case.
In any case, thumbs up for ABS progress!
ABS on a smooth grippy surface is hard to match. but throw any amount of dirt, debris, etc in the way, and it's a mess. Out on the track where you don't usually brake below 25mph, I'd rather not have ABS, but on the street where 25mph to Stopped is the big determining factor between a collision and a "whew". ABS is great.
On the track, I'd be more interested in the 120-40 distances and the fade resistance, where I'd bet the USDM RS will outperform the USDM GSR.
Originally posted by xtnct
metaphysical>
That is old school....
metaphysical>
Originally posted by norice
What he said. The debate over whether ABS is superior to a good driver has been settled in the past few years - a good modern ABS system is far superior to any driver on a paved surface.
Sorry to change the topic off of ABS systems, but does anyone know what invoice is for the EVO 8 RS?
If base MSRP is $26,500, I imagine its like $25,000 flat?
Also bear in mind that the RS may have been tested under different road surface conditions and possible different tire conditions. We don't know if the cars were compared side by side or the EVO VIII was simply a reference point on which data was drawn from on an earlier date. Guess I should take a browse at the mag.
2) RS comes with 15" wheels on 205 R60, your 8s come with 17" 235 ZR45s
3) ABS and no ABS wont make any difference stopping in a straight line....
Originally posted by Angel Of Mercy
1) Correct, RS comes with 15" standard disk brakes....
Originally posted by MP5
Yup Whats the problem? Both will break a 1/4 football field faster than those toyotas
Not This One
Or This One
