Double pumper options or something else?
Old Jan 24, 2012, 01:37 PM
Graphic's Avatar
Who all makes quality double pumpers besides buscher? Or something similar that doesn't require too much modification? What other options are out there?
Old Jan 24, 2012, 06:50 PM
prockish_03evo's Avatar
you have a couple different options
1) Full blown makes a nice dual intake setup but there is known problems when running under 1/4 tank of gas....
https://www.evolutionm.net/forums/ev...ock-lines.html
2) Or if you think your up to the task you can build your own. This is the path i choose so i could use (2) Jay Racing 342 Fuel Pumps!
https://www.evolutionm.net/forums/we...umper-fab.html
Old Jan 24, 2012, 07:49 PM
sourcelx's Avatar
You could also go with a 400lp single pump like the detchwerk(sp) or walbro has one aswell. If you want it to flow better than a 255 you need to rewire it and at that point you need a fpr.
Old Jan 24, 2012, 08:07 PM
Teal2nnr's Avatar
Just curious...but you don't like the buschur option?? its pretty simple and very well put together.
Old Jan 24, 2012, 09:05 PM
SDevo13's Avatar
What kind of power are you looking to make, and on what fuel?
Old Jan 24, 2012, 09:16 PM
Blue91lx's Avatar
I just did a Warlbro 400lph In tank. Fairly straight forward install.
Old Jan 24, 2012, 09:26 PM
Blue91lx's Avatar
....This isn't true. Out of the box it will outflow a modded 255lph. Oh, and you don't need a FPR either.
Old Jan 24, 2012, 09:44 PM
Dynotech Tuning's Avatar
BR Double pumper doesn't get much simpler. Drop it in and its the last FP upgrade you will need for a long time. Unless you plan to make 800+ HP.
-Brian
Old Jan 24, 2012, 09:48 PM
Blue91lx's Avatar
It's just hard to justify for some, as for around $150 you can get that Warlbro 400. Many people never enter the territory in which the DP is needed. I plan to push this 400lph to 650whp when I do my testing come summer. I also spent $30 and made an 8an stainless firewall to fuel rail line.
Old Jan 24, 2012, 09:53 PM
tim85851's Avatar
do you have instructions on how to do this? or a link to a thread that you followed?
Old Jan 24, 2012, 09:59 PM
Blue91lx's Avatar
Took about 5 extra minutes:
https://www.evolutionm.net/forums/9653510-post222.html
Old Jan 24, 2012, 10:11 PM
10isace's Avatar
Did you clamp yours down like MAP did? The clamp is considered a potential problem that could cause the pump to stop working. If I ever need a bigger fp, I'd like to go this route if I know it's securely in there and won't fail from the clamp.
https://www.evolutionm.net/forums/9653825-post235.html
Old Jan 24, 2012, 10:16 PM
Blue91lx's Avatar
I forget where I was reading it, but the clamp became an issue if you cranked it down, rather than just making it "snug". When you clamp it extremely tight, I guess it affected the flow dynamics inside of the pump. However, take that with a grain of salt, as I can't find the thread where I read that.
Old Jan 24, 2012, 10:25 PM
drb
drb's Avatar
If you are concerned about the hose clamp squeezing the fuel pump you can modify the hanger to allow you to keep the stock retaining clip.
Old Jan 25, 2012, 02:42 AM
Graphic's Avatar
I don't like how I was treated when I was asking him questions about head studs and buying a turbo upgrade from him for my Evo. I am a TPM for Microsoft and customer services is #1. That is how I like to be treated that is how I like to treat people. I have since decided to take my business else ware.
I want to two tunes. One on E85 and one on 92. I want 600 or more on E85 and 550-600 on pump if that is possible with my setup? I need a ported or bigger throttle body/intake. But that wont be till after my car is completely put together. I'm waiting on some parts from Greg at GSC .
How much will this support on E85 and on pump?
Quick Reply: Double pumper options or something else?
