Need help locating a JDM or EUDM Evo IX Serive Manual or OEM Parts Supplier
As the title states, I need to find out where I can get a copy of the JDM or EUDM service manuals for an Evo IX. Or I need to get in contact with a company who has the ability to order OEM parts and ship them to the continental 48 states.
The end goal I am trying to achieve is to replace the crap manual HVAC controls in my car with the electronic overseas counter parts. Yes, I realize almost everything behind the dash will need to be replaced. Yes, I realize it's going to be expensive. I still want to do it. I just need some information! Any information would be greatly appreciated!
-Acree
-Acree
I order JDM Mitsubishi parts all the time directly, but my JDM software update is version 145 / 1.3.0.2, which goes through February of 2007, and does not show the electronic control assembly, simply the manual control assembly.
I show a part number of MN185096HA for the entire JDM HVAC controller assembly which is the only part number for 2000-2007.02.3. If you can find out what year/month Evo 9 it is available in, I would likely have better luck.
I can ask my contact for a part number request as a start, and if so, then there would be several other parts I am sure. I would need illustrations and part numbers for all of the electronic stuff from Mits.
As for the USDM manual HVAC controller assembly, I have a couple different part numbers listed in the illustration, but the general part picture is the same as the JDM evo info I have.
I was able to locate EUDM manuals for the 7, 8, and 9.
If I have the correct parts number, are you able to order a part that is for a European (German to be precise) Evo, from Japan? The issue of RHD, LHD, becomes an issue with the heater-a/c air mixer assembly.
-Acree
-Acree
It shouldn't be an issue; it is worth a try as I am going directly through Mitsubishi of Japan.
Simply send me an email at tmzperformance@gmail.com as I rarely jump on this forum if you don't see me online. It will work substantially faster than PM'ing me on this forum.
Ahhh, that sounds like a real "fun" time.... Yeah, if you get me the part number I can see what I can do. This is probably one of the most interesting parts requests I have done....
