Got a Reflash and cat-back...what next
I have the Works P2 93 Octane relash, and UR 2.5" cat-back exhaust. What should I do next for more power?? I don't need an MBC, and a filter system is no good with my P2 (from what I've read) so those are out.
How about on a budget of $300-$500. Looking for bang-for-the-buck. Let's here em!
Cams are too pricey for me.
I don't want coil-overs, and not looking for any general suspension or braking help.
down-pipe is a great power adder and it is around $300 bucks and easy to install.
cheap tires cheap wheels cheap brakes cheap suspension cheap car tires motorcycle race
I have the 3inch turbo back ultimate racing with high flow cat and it is not that loud at all, I think the catback makes somewhere near 10-12whp and the full turboback which includes the downpipe makes about 25-28whp and belive me on the top of the rpm range it pulls much harder.
Order a UR downpipe by tomorrow and its only $250. Even though you have a flash, a boost controller should help. The downpipe-boost controller combo will really help spool the turbo.
Originally posted by 4-BNGR
Can you hold boost over 21 psi, 22 psi, 23 psi, 24 psi, in every gear? If no then you need a boost controller - unless the P2 somehow prohibits it's function - unlike the DynoFlash.
Either way, I think that's plenty of boost. Don't want to push the cut-off point, I wanna stay in the safe zone.
