For those who have/had JDM 8 MR headlights
Hello. I have questions for those who have/had JDM 8 MR headlights. After I installed JDM heads yesterday, I noticed it was crooked/uneven but I was told JDM MR headlights do not have a flat cut-off pattern. This is how they are produced in Japan for more visibility since they are RHD cars in Japan. In case like this, should I lower driver side head manually? Is so, how? Thank you.
pretty sure you can manually adjust the beam with a wrench. but even with both lights perfectly aligned it will always shine higher on the left side. Since they drive on the other side of the road, the beam pattern is designed to shine light on the side of the road for visibility.
I have only seen one person that took the time to retrofit the inside of the headlights with a "shield" to get a flat cutoff pattern.
nevermind you explained the above.. but ya i did what you said and adjusted them for awhile, mine are close but still no where near where they should be.
Thank you so much for your answers. It looks like previous owner already lowered driverside low beam. That's why I am getting uneven the layers. I put my car againt wall and it shows driverside is bit lower than passenger side.
Hello. I have questions for those who have/had JDM 8 MR headlights. After I installed JDM heads yesterday, I noticed it was crooked/uneven but I was told JDM MR headlights do not have a flat cut-off pattern. This is how they are produced in Japan for more visibility since they are RHD cars in Japan. In case like this, should I lower driver side head manually? Is so, how? Is it normal that one of low beam shoots farther down the road than the other? I get layers by this. Any input would be appreciate. Thank you.
Here's one example - obviously since it's a Legacy most of it won't apply to you, but it does demonstrate the difference in the plates.
http://legacygt.com/forums/showthrea...n-127120.html?
Spraying light into oncoming traffic is not a terrific idea
^ Thanks. I found this. Post #23 shows difference between JDM vs USDM low beam pattern. https://www.evolutionm.net/forums/ev...post-up-2.html
I have no guts to do this.
Ryuartz
15
Feb 13, 2012 03:46 PM
Ryuartz
Feb 13, 2011 07:14 AM
Ryuartz
Dec 17, 2010 02:45 PM
