Is a tune needed for adding a MAF adapter and cone air filter for an EVO 8?
Old Feb 27, 2012 | 09:33 AM
traitorzxiong's Avatar
I recently picked up a stockish EVO 8 and the previous owner installed a MAF adapter with a cone air filter. Will I need a tune with the air filter or would I be fine? Thanks!
Old Feb 27, 2012 | 09:44 AM
Kim@Forged's Avatar
Hey There.
You should be absolutely fine without a tune!
Old Feb 27, 2012 | 09:59 AM
Originally Posted by Kim@Forged
Hey There.
How sure are you??? I've been seeing/hearing mix reviews.
Old Feb 27, 2012 | 10:36 AM
Chaser_41's Avatar
I ran an aem intake and Buschur turbo back for a few weeks before getting a tune. Ran fine. But figured out I was running rich when we finally threw her on the dyno.
Hope this helps
Old Feb 27, 2012 | 10:52 AM
Hope this helps
Thanks for the info.
Old Feb 27, 2012 | 11:12 AM
ReaperX's Avatar
I just installed one yestered with a Perrin Filter and here are my thoughts on that....
It depends on if you're car is currently tuned for your current mods. My car was tuned with a 3" TBE @ 23psi. I did a few pulls prior to install just to make sure my afr's a boost where still good (haven't full throttled in a while trying to save some gas), which they were.
Installed the filter and since then when I go full throttle I am now hitting 25psi. My afr's are still where the need to be after the install. I know the car is breathing much better now but will verify everything once I can toss it on the dyno this spring/summer.
You should be fine as long is it doesn't start going lean under boost, that was my only fear and she is sitting pretty on afr.
Old Feb 27, 2012 | 02:59 PM
03BoostedVIII's Avatar
Ok quick and dirty.
WILL you be ok not getting a retune - Yes most likely.
Will you get the most out of your car without one - absolutely not.
Conclusion - Always best to get a retune whenever you mod your car's engine performance . Suspension of course not necessary lol just an alignment.
Old Feb 27, 2012 | 03:05 PM
Thanks for the info. Just as long as the engine doesn't get harm in anyway, it's cool with me!
Old Feb 27, 2012 | 03:46 PM
You'll be fine then lol.
Old Feb 27, 2012 | 04:13 PM
SDevo13's Avatar
Anything that alters air, fuel, or spark entering or leaving your motor = tune.
Old Feb 27, 2012 | 05:06 PM
Ryuartz's Avatar
Same boat here. I would like to get more info on this. I just want to hear spool sound.
Old Feb 13, 2014 | 08:07 PM
meric's Avatar
Shouldn't have a large effect as these cars run rich to begin with. Also you are not changing the maf sensor it self which will have a massive impact on tune. You are just utilizing the efficiency of your oem sensor. Always keep in mind a tune should be done when a major bolt on or sensor/engine mod is done
Old Feb 13, 2014 | 08:36 PM
egis's Avatar
i have BR maf adapter and cone air filter and they told me no tune needed.it's just an adapter like what 3/4".i run like that almost 4 years without problems.
Old Feb 14, 2014 | 06:32 AM
ReaperX's Avatar
This thread is 2 years old guys
Old Feb 14, 2014 | 07:35 AM
egis's Avatar
thats right but maybe op still dont know if he needs tune or not lol
WickedRSEvo
May 31, 2016 03:58 AM
elhalisf
Jul 6, 2015 05:06 PM
Randal
Sep 12, 2013 03:26 PM
metaevo
11
Nov 8, 2012 10:00 AM
EvoX-LI
Evo X How Tos / Installations
16
Aug 28, 2009 03:55 PM
