engine check light
Ninety nine times out of a hundred it is just going to be the bulb. So, do a bulb swap and if that doesn't fix it then get back to us. Use a new bulb not one you swap from another location. Also, don't be surprised if you find one or more illumination bulbs out after you mess with the combination gauges. They like to fail anytime you pull the gauges.
Evoguy!123
Jul 21, 2016 05:46 AM
