When car turns on knock noise?
Soo, I have changed the timing belt, head gasket and all of the gaskets possible on my car, I got it all together now and the car runs fine just when i turn the car on there is a little knock noise I dont remember hearing it before? also sometimes I can feel like cracking noise under my feet. If anyone can help it would be appreciate. Thank you
I dont think it is the CV joints, Its something else I feel like, when I turn the car on there is one 1 knock and it stops, I just dont want i to escalade into more knocks.
Wouldn't be surprising if they were starting to make noise at that mileage. Mine are starting to make a bit of noise when it's really cold and I'm at about 45K miles.
If the noise is louder when you are accelerating around a corner then it will be you CV (constant velocity) joints.
You can try replacing the grease on them, that can quiet them them down. Replacing them isn't a massive expense though.
When I drive the car there is no noise, I only felt noise when i was breaking but that was my breaks, LOL. Also i was driving today and i let go of my steering wheel and the steering wheel just went to the right side. I do think it needs alingment tho.
Its a 2006 IX MR. The suspension is stock teins. Now when i drive somtimes when i accelarate and slow down i can feel crackling and little knocks, I did remove the top engine holder piece that holds the suspensions, when I was removing the gaskets, can there be somthing with that? The bigger knock is when i turn the car on.
Yup MR teins. I havent tryed that yet but problems seems to be escalading, this morning when i tryed to show it my mechanic friend the knock was gone! Then 1 hour later it was back. How messed up is that.
