HKS 274/278 Cams
From what I've seen with the 272's they do ok. I've never seen a graph with the 274/278 duration. You should see decent gains depending on the lift and other supporting mods....
I have these cams in the car right now and I have no problem with them at all. With the hks 7046 turbo I made 385 with pump on a conservative tune. I'll post the dyno graph when I get home.
Forged internals, new turbo, cams, and bigger injectors (ID 1000's) are the main power increases. I did not lower compression. I basically went from a fuel pump and tbe tune to a built motor. So I do not know what the power gains would be over a stock cams.
What brand names did you put in for your build.? What evo do you have an VIII or IX.? I know my roommate had stock block and head. Intake turbo back exhaust uicp/licp and intercooler and made 381whp with stock turbo and it was an evo IX.
SrBlacksheep
13
Dec 1, 2013 09:09 PM
meckert
45
May 5, 2012 04:46 PM
Sean@Iveytune
Jan 10, 2011 11:41 AM
