Removing check engine light from the Ecu?? Possible
In the ECU software there are a lot of settings that can allow us to turn on/off the ODBII readiness codes that will disable the CEL.
Your tuner obviously turned off all this stuff and you will need a retune. When you get it re tuned, make sure to tell your tuner to turn on all the ODBII readiness codes, and to check the injector latencies.
Once that is done you should have no problems passing smog.
I would also recommend that you spend some time reading the ECUFlash section. Then pick up a laptop and matrix cable so you can do some better diagnosis next time
good luck
good luck
Good advise and thank you... If I get access to a cable and laptop is it as easy as turning the obd2 readiness setting on??? Leaving the tune untouched?
good luck
good luck
Yes, as long as you can locate all of the codes set to "0" in the periphery section that you for sure want to change back to "1". That's why I recommended that you start from scratch with an unmodified OEM rom. Make sure you set your access level to "Developer", or it won't allow you to make the changes.
Evoguy!123
Jul 21, 2016 05:46 AM
rino
Mar 7, 2011 05:37 PM
