Rattle Noise
Rattle Noise
Sorry if a thread similar to this has already been posted, I did my best to try and search for it first. I own a Evo IX MR and just hit 26k on the clock. I hear this very annoying rattle noise when I rev to about 3000 rpm. It sounds like it is coming from under the hood but I am not 100% sure. Have any of you had the same thing happen? If so how can it be fixed, because it is SUPER annoying. The rattle sounds almost like a scratching type noise, it is kinda hard to explain.
confused at your description. the exhaust doesnt meet the exhaust manifold ever.
top heat shield covering the exhaust manifold or the lower covering the o2 housing with the o2 sensor sticking out?
im assuming the lower heat shield. if thats rattling just remove it.
crack in what pipe?
crack in what pipe?
^^^ if that's a picture, it didn't work. like sujinX said sounds like your lower heat shield, 3 bolts to remove and its off. As for the crack ill wait for the picture to better help you.
future reference, check all your clamps for intercooler pipes ect make sure there not rubbing, also make sure nothing is touching the pan my buddys oil cooler fitting was rubbing the oil pan causing a rattle
blknblubkrdude
Mitsubishi TC-SST Discussion
10
Apr 10, 2015 09:08 PM
Turbo Ghost
Sep 1, 2014 12:26 PM
