Fog light button not working
Did you check to make sure that the wires are all connected? As in, that they're pushed far enough into the physical clip so that they're contacting?
Wires occasionally pull out of the clip while the clip is engaged and lose contact.
you want them on all the time when the head lights are on?
well tomorrow I am going to pop the switch out and see whats up. hopefully i dont break it more. i did check the fuses and they are good, but is there a relay for them? all the fuses just show light pictures...
Negative on the jumper wire. I played with the fog lights a bit and made a diy to have them on anytime the parking lights are on. It's been a bit but I think the switch sends a pulse as you push the button to some kind of lighting computer which then sends out the constant signal to the relay.
