help: install boost guage
Old Apr 20, 2012 | 11:57 PM
hachansoo0413's Avatar
Hello,
I have evo 9 MR, and havent installed guages yet.
I just dont wanna put new vaccum hose from engine to dash, if I can lol
Does anyone use the stock vaccum hose from MR guage for AEM boost guage?
Old Apr 21, 2012 | 12:05 PM
boostedmkiii's Avatar
I would think you can use that hose without any issues...
Old Apr 21, 2012 | 12:09 PM
Thore's Avatar
I agree. I don't see any reason why not. Although if it's old and showing signs of breakage, I would replace the line.
Old Apr 21, 2012 | 12:22 PM
ak47po's Avatar
Originally Posted by hachansoo0413
Hello,
I just ran a new line and run two boost gauges,factory and the other Defi no problems.
Old Apr 21, 2012 | 01:10 PM
runningonE's Avatar
I unpluged the vaccum hose from the back of the factory boost gauge and ran it to my AEM Tru-Boost with no problem. I did it for the simple fact because I was too lazy to run another vaccum line. The only problem I can think of is where your going to place your new boost gauge.. Because I mounted mine right above the steerting wheel and the hose just made it.
Old Apr 21, 2012 | 02:30 PM
nytalonTSi's Avatar
I'm using it for my boost gauge. I have a mechanical gauge, but it works fine.
Old Apr 21, 2012 | 03:09 PM
clubEVO93's Avatar
Im using the line. right up close to the manifold.. I tapped it twice for the oem and defi. I heard you want it close to the source of pressure for more accurate readings tho. Gl
Old Apr 24, 2012 | 08:37 AM
thanks for all inputs guys!
I guess I dont need to make another vaccum line for my guage lol
Old Apr 25, 2012 | 10:46 AM
djdnav's Avatar
I have an mr also. I just t'd off the stock gauge, no problems.
Old Apr 25, 2012 | 10:59 AM
Murf's Avatar
Used the MR gage package boost line on my defi boost gage. You will have no problem.
Old Apr 25, 2012 | 11:08 PM
When installing new guage over MR guages, is there someone who moved them to either A pillar or stock radio location?
Im planning to get 3 pod a pillar,,, it will be great if someone gives me little experience
Old Apr 26, 2012 | 08:38 AM
runningonE's Avatar
I know you can relocate the MR gauges to where the radio is. All you need is the radio relocation kit. Which can be found here..
http://www.streettunedmotorsports.co...cation_kit.htm
As far as relocation them to the A pillar I'm not too sure about that. In my opinion they would look a little goofy in the A pillar since the gauges are so small.
Good luck.
murderedout
Feb 24, 2016 05:15 PM
murderedout
Feb 23, 2016 09:25 PM
Bootys Evo
Aug 24, 2015 12:07 PM
babaz7
Feb 16, 2015 02:14 AM
xxNosTankxx
12
Aug 14, 2007 02:37 PM
Quick Reply: help: install boost guage
