fuel pump priming?!
fuel pump priming?!
ok so a guy on here asked me to prime my fuel pump to see if my problem can get resolved. Problem is I dont know how to do this. Can anyone explain how to? This is what he wrote to me ...Cycle your key to the ONII position. You should hear the fuel pump priming. (pressurizing the fuel lines for a quick start up) It makes a humming sort of noise. Do this test a few times. To make sure it primes
wheres the onii position? and how do i cycle any help?
Turn the key to the On Position (One "click" before start.) This is when you'll hear the fuel pump. Then turn the key off. Then turn to the On Position again, then off again. Doing this between 3-5 times is cycling.Hope this helps
No, your fuel pressure should stay close to to the same. If your losing pressure each start and having to prime it each time, you either have a bad FPR or have a leak at the fuel pump somewhere that is bleeding off pressure.
Is this a new problem after a fuel pump install or some other change?
If that checks out, I would pull the fuel pump and make sure the connections are good and tight at the housing and where the pump connects to the housing its self.
If you plan on upgrading to a wally anyways I would do it after checking the FPR anyways. Dont want to just throw parts at it with out it begin fixed. It could compound your problem.
Sorry to hijack this thread, but I'm having a similar problem.
After installing the walbro 400 hardwired to battery and Aeromotive AFPR, my fuel pressure drains off over a couple hours and takes me about 5 goes to start the car.
Any suggestions on how to fix this?
EvoFredo
Apr 24, 2012 09:54 PM
