Glove box latch
Not positive without looking at it, but I would wager that there's a little lever underneath the lift latch that that particular latch actually activates. You can probably just push/pull on that and it should just pop right open?
Basically... you're activating the mechanism without using the lever. Make sense?
Looks like I am going to have to pry open the box and replace the parts that I break. I wanted to know if anyone with an Evo 8 would be willing to take a picture of hook that is mounted on the inside to see how its mounted. I am debating if I want the cut thru the hook or if I am to break the lever attached to the glove box.
Ok, so the little bump in the middle is what is holding on to the hook inside. On eiher side here is a hole ha goes straight ouside the glove box, under he latch. What you have to do is get a wire or something and bend i a 90 degrees push it in the hole and ry and push down on the latch.
Good luck!
Good luck!
FS[Northeast]: Evo IX Interior Panels *Cheap*
MisUnderStood
17
Dec 26, 2014 10:18 AM
