Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
So my panel lights dont work with i turn on the headlights but work when the headlights are off i checked the fuses and i get power to the dimmer switch so im thinking maybe the dimmer is bad.
Does sound like the dimmer switch.Hook a volt meter up to the out-put and see what you got. Voltage should go up and down as you adjust the switch.
As it turns out I have an extra dimmer laying around. If It turns out thats the problem your welcome to it.
I just checked the dimmer with the volt meter and its stays at 11.82. can u send me that switch? if you dont mind thank you
