EGR remove or no?
#31
Thanks to this thread I reached back there, noticed a popped off hose from the EGR valve, and found what is likely the reason behind my knock CEL going off.
Ziptied it for now, but I'm going to annihilate that thing, I'm going to crucify it. It's been 6 months of torture since that boost leak test, this useless piece of crap has just been dangling around, silently taunting me.
#32
nope. this is all wrong. EGR's are an environmental/emissions addition. It has no positive effects on performance. It has the OPPOSITE effect. The point of the EGR is to recirculate a portion of the exhaust gases back into the engine to keep any unburned fuel/combustable pollutants from being sent out the tail pipe. They recirculate, and get burned in the engine. Intake air temps WILL drop with the removal of the EGR. They have to if you are removing hot gases from the cold intake charge.
removing the EGR eliminates the CEL you get from the EGR hoses popping off. It might pass emissions without the EGR. The EGR is more for higher flow than idle.
In short, you don't need EGR if you dont have emission in your area and if you use a stock exhaust you will still most likely pass emissions without your EGR. People have been ripping them out ever since they started putting them in cars in the 90's.
rchangwu
17
Feb 21, 2007 03:57 PM
