Evo fail....
#32
I have some questions about what happened.
1) What was the final cause of the ticking?
2) Who tuned the car for 91?
3) Why didn't you look further into the ticking being all 4g motors tick unless its a rod knock?
4) Was there an upgraded oil cooler?
Iam just curious about what actually happened. I understand being my car was road raced for years before I bought it, but what exactly happened to make you think its a motor failure.
2)Tuned by Yimi Sport Tunning in L.A.
3)you could tell that the ticking was really bad at start. I changed the oil and found no shavings, and replaced all the lifters. In the end I raised the car, started it and listened by the oil pan. It was crazy loud. I drained the oil again and there were shavings.
4) no oil cooler upgrade, stock oem.
#33
1)The cause was a coupler clamp that turned under heavy boost on its own in front of my radiator fan and it was stuck. I ran 3 fast laps on the track to where it overheated and died. I started it back up when it cooled but a rod was knocking.
#36
not to rub salt in the wounds, but blowing all these motors isnt bad luck. either they werent built right, werent tuned right, or you just arent staying on top of thing good enough. they need constant attention, if something sounds or feels off, it is. you need to log often. if you just start it, drive it and treat it like a camry, you will blow it up.
#38
After having Out Front M.S. build it again I put it all back in but after exactly 809 miles it spun a rod bearing. They claimed that the could not find out the culprit. I say Bull ****. Rather get rid of it all together they gave me an oem STI motor for half price so I did it like a gullible dumbass. After putting 5k on the motor I traded it in for my Evo 9.
Tune and or lack of attention had nothing to do with it. There's no reason with any car why I shouldn't be able to reuse an oil pickup. Subaru uses a braised aluminum pickup that WILL break if you reinstall it. I've "to date" built 6 Subaru engines and every time I take out their oil pickup, I break it intentionally so they do even think of reusing it. Out Front never even recommended that I buy it. It was like ordering food to them. Now all the Subaru short blocks I get come fom Yimi Sport. Evo is a whole different ball park, everything that's easy to do to a Evo is a pain in the *** on a Subaru. Everything easy to do on a Subaru is a pain in the *** on an Evo. The one time I take my car to a track, it overheats because I was paying attention to my tune. I was watching my AFR and Boost but not my temp gauge. All my buddies with their subies that I built had no problems, just me......
#39
I really wanted to go Buschur but it was a 6/8 week minimum wait time. I don't have that long. As far a Map, they do not by any means have a bad track record. I searched but could not find anybody with complaints that lead to MAP being a bad idea to go with. Hopefully all will go well but only time will tell. I'll be sure to post my experience
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
#40
Some things that could help would help prevent this situation from ever happening again in a road race situation:
1. Switch to Higher Octane Fuel(100 or E85)
2. Oil Pressure Gauge
3. Water Temperature Gauge
4. Oil Temperature Gauge
5. Performing a Boost Leak Test right before motor-sport events
#41
#42
In my 06 STI I built the engine with Cosworth parts. Built short block with stock heads. The mistake I made was not replacing the oem oil pickup with a Killer Bee oil pickup. The oil light came on with 4,800 miles on the engine. The really bad thing is that the oil light only comes on at 2.7 psi of oil pressure. Instantly I knew the engine was going to need to be rebuilt so I did it again.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
#43
i had a built 07 sti with a 35r, everyone knows about the pickup tube issue, thats where the paying attention part comes in. research all the weak points and address them to eliminate as many potential failures as possible. your oil cooler was contaminated from the first bad motor, that wiped out the second one. i hear you on the easy things to do vs. the hard things to do. i prefer wrenching on subarus by a long shot. at least the engine is mounted the correct way. ![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
I replaced the oil cooler along with the oil pump after the first engine went from the oil pickup. Oil lines to the turbo were cleaned by Out Front in their tank. Theye were all that I didnt replace. Debris was not the issue. Out Front blamed me for the use of ultra gray. They stated that some got into the oil galley in one of the cams. Bull**** again says everybody on Nasioc. On start up you are at 90psi of oil pressure. Its not J.B.Weld and even that might not hold that kind of psi. Their mechanic didnt mic it properly is all anything leads to. I got the bill and they washed their hands of it.
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
#44
Believe it or not, taking this engine out really really makes me miss my STI. ![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
