Burshur Muffler Delete Pipe
Buschur Muffler Delete Pipe
Just installed the Buschur muffler delete pipe ... took less than 1/2 hr. I am amazed at the weight difference between the stock muffler and the new delete pipe. Fitment was perfect.
What is suprising is that with the new muffler delete pipe the car is barely louder which I guess is a good thing. The tone seems a little bit deeper.
I know that alot of people have said that you loose boost psi with the pipe ... mine appears to have lost about 1-2 psi @ peak but settles down to the same 16psi.
The motor does appear to be slighly smoother in the upper rpm range.
My question is am I actually gaining any power ? Or have I just moved about 5 hp from lower rpm to higher rpm ?
I am really setting the car up for the Dynoflash so I think that this is the 1st step to that.
Kinda yes you gained so hp off of the pipe but lost some boost which lost some power, just get a boost controller manaul or electric and you will like it alot more.
WTB[Northeast]: Muffler delete pipe for IX MR
AJCaron12
Sep 19, 2015 03:01 PM
PinnacleChronos
Jun 6, 2004 04:17 PM
