Evo 7 wont run issues
Guys im at the end of my wits with this one
Evo 7 will start and run for 5-20 so seconds then stops, try to restart it and it will fire and die
Leave it sitting for 10 mins and start it up it will run for 5-20 seconds then die and the process repeats ie leave it sit and it will fire and run
Parts ive swapped over to eliminate issue
Airflow meter
Cam angle sensor
Fuel pump relays 1,2,3
New spark plugs
Checked fuel pump operation
Checked compression all at 180psi
New battery
Car initially came in for new wastegate actuator, Ive touched nothing else
Any help would be awesome!!
Airflow meter
Cam angle sensor
New spark plugs
New battery
Right i tried new leads, coil, fuel pump with no luck
Fuel pump continues to run when car stops, then turns off as it should, so not a fuel pump or delivery issue.
Funny thing is i started it from cold and it run for a couple of minutes, then died, then wont start unless you leave it for a few minutes and runs for 20 odd seconds then dies etc etc
So seems to be when it gets to operating temp?
pennies_hatchie
68
Mar 5, 2023 08:02 AM
hooliganSKATE
Jul 16, 2015 06:21 AM
