Dyno tune vs Email order
Old Sep 1, 2012, 09:41 PM
  #76
codgi's Avatar
Originally Posted by 2OO3SILVEREVO
the dyno tunes dial in the afrs more accurately and let u run more efficient with the fuel provided by adjusting the timing also
What? Where did you hear this? . the key to tuning AFRs correctly is skill and a good wideband. You don't need a dyno for that. Adjusting timing is done separately from fueling regardless of where its done.
Old Sep 1, 2012, 11:49 PM
  #77
Boosted Tuning's Avatar
Originally Posted by hermin0000
i have a dyno tune. My brother (speed3) had the email in tune.
Here are some pro's and cons of each.
Dyno pro: Fast, easy, accurate
dyno con: Cost, if something isn't right with your car and you end up with a bad tune, there is no time to fix it. You have to go home, fix it, then bring it back to the tuner and pay again to get it tuned. This leads me to the email tune
email pro: Tons of flexibility, if the tuner sees something funky, he instructs you to fix it, and then another pull.
See, with the email tune, you can have alot of time in between pulls to correct/fix anything with your car. (days, weeks sometimes) at a dyno, you are very limited.
Email con: You could get a ticket when doing your logs, takes longer.
+1
hktrigguy
24
Feb 16, 2017 06:37 AM
cumminsracer14
Dec 2, 2016 02:53 AM
Decker@Forged
Jun 29, 2016 08:32 AM
Rguy
19
Jul 16, 2015 09:56 PM
wvrx
Feb 14, 2015 05:15 PM
Quick Reply: Dyno tune vs Email order
