woke up to a rough idle
Hey guys,
I need some help, I woke up this morning and started the car and was idling rough as can be, checked for the loose hose, and any other vacuum leaks, cleaned the maf. My af gauge was freaking out, wondering if it bad gas, or my fuel pump going bad.
Car has 109000miles on it, tomorrow morning ill be checking the plugs and anything else I come up with
Update, af relaxed that was probably bad gas from turkey hill, I knew I had to replace the exhaust manifold gasket because it was leaking, checked the plugs and they are gapped correctly at just under .25, I've replaced my Pcv valve that was blocked. Car pulls awesome again now that the leak is fixed but the idlr is still off, like its laughing at me. Ha.....ha.....ha
