Car runs like crap after injector and walbro install
So I installed some FIC 1050s and a walbro 255 today. I did the injectors first, car started right up and idled decently (for 3 minutes or so), i figured i had installed them correctly and moved on the the fuel pump.
I installed the walbro, again only with 1 little hiccup in the high pressure hose popping off because I didn't snap it on tight even, the car died and fuel went everywhere, i reconnected it and again it started right up.
About 5 minutes into letting the car idle it got really rough (sounded like my cams went from 272s to 290s lol) and started to blow some smoke out the tail pipe (smelled like gas and fairly black/grey ish in color)
Then i took the car out around the block to see if it ran good enough to limp it to a shop to get it tuned later in the week and the car runs like ****, it misfires, doesn't go above 3k rpm. During the drive it stalled once and didn't want to start back up again.
I figured the injectors would make the car run rich, but is this out of the ordinary?
My advice. Don't drive it until you get a tune. Matter of fact ask the person tuning it to send you a startup map to at least get you to them so you don't do any damage.
There is such a thing as running too rich.
Oh wow I just didn't think it would make the car almost un drive able, I just I'm gonna have to tow it to the shop or throw the stock injectors back on and have them put em in at the shop
Take those injectors off, replace them with the stock ones, and have whoever is going to tune it reinstall them. You may want to get a new set of spark plugs as well and hope you don't wash down the cylinder walls with fuel (which will remove just about any lubrication in said cylinders) leading to much bigger issues.
Something reasonably airtight - a ziploc baggy would work fine, or at least that's how I've always stored mine. Never hurts to lube up the seals/o-rings with WD-40 or motor oil (hell, spit will work ).
