need help. new* NO AC ? not working at all.
Old Jul 11, 2012, 05:44 PM
jeremy52048's Avatar
hey guys ive looked everywhere on this forum for help but just cant seem to find out whats going on.. i have a 2005 evo 8, my ac just stopped working completely, as in no power at all , it doesnt kick on at all. need help asap
Ive heard it could be the air sensor on the center-right vent?
Old Jul 11, 2012, 05:51 PM
jameelrose's Avatar
I had this issue. It was the large green fuse in the inside fusebox. The contacts for the fuse melted.
Old Jul 11, 2012, 05:56 PM
kamote2000's Avatar
+1 check the fuse.
Old Jul 11, 2012, 06:11 PM
gomcar25's Avatar
fuses and then relays
Old Jul 11, 2012, 06:24 PM
hatesposers's Avatar
fuses, relays, check R134a level then check your compressor clutch air gap
Old Jul 11, 2012, 09:33 PM
checked out all fluids as well as compression. also checked the relays and fuses. Ive had it for 2 weeks so im new to the evo! I wonder why these cars have so many AC fuses/Relays?..
The fuses under the dash/hood were all good
Old Jul 12, 2012, 04:05 PM
any help would go a long way...
Old Jul 12, 2012, 04:22 PM
Silver Sponsor
RallySport Direct's Avatar
Anything more than fuses and relays will probably require an inspection from a shop.
Have you tried to manually turn the compressor on by bypassing the relay? How did you check the pressure in the system?
That could give you a good place to start for diagnosing.
Zach
Old Jul 12, 2012, 06:01 PM
my buddie had checked it at his shop... he said it was most likely an electrical problem, But i had someone else tell me it could be a sensor that burns out near the air vents?
Old Jul 13, 2012, 08:51 AM
svt_lightning01's Avatar
When you turn the ac on does the fan kick on as well as the compressor? You say no air blowing inside the cab at all? Not even hot? If youre getting hot air try some 134a
Old Jul 13, 2012, 08:53 AM
theres absolutely no power to the AC/Heater console it self... like when you push in the button for ac or the any of the 3 options the green light does not turn on, so nothing works
Old Jul 13, 2012, 08:55 AM
did you change any of the relays around? Sometimes relays goes bad without any physical appearance change. you may try changing the AC relay with another one thats the same under the hood and see what happens. Sounds stupid but its happened lol
Old Jul 13, 2012, 08:56 AM
If not a fuse/relay problem then its definitely an electrical issue whether it be a loose ground or cut/worn wire. I can't think of anything else on the AC system that would cause it to completely not respond unless the switch/button you are pushing has went bad.
Old Jul 13, 2012, 10:01 AM
lol yep checked the relay with the honk! nothin... hopeless in this heat man
any way to check the ground? no sure which one that is
Old Jul 14, 2012, 06:21 AM
Berts24's Avatar
so is your fan inside the car not even blowing? as in you don't even have heat?
Quick Reply: need help. new* NO AC ? not working at all.
