Towing Question???
Towing Question???
Hey guys I have what may seem like a stupid question but im unsure and have never done this before. I'm going to have to tow my car within the next few months to go get built/ tuned making about a 3- 3 1/2 hr trip. My one buddy said he would let me borrow his diesel F-250 to tow it. Now my questions are:
The car currently doesn't have a valve cover, brake calipers or wheels on it.
Now naturally I'm going to put the wheels back on but would it be okay to just throw the valve cover on and throw 5 or 6 bolts in just enough to start it and load it onto and off a trailor?
Also I don't feel like putting the calipers back on they were just rebuilt but the car is getting new pads/ rotors/ ss lines ect when it gets built is there any way to load onto a trailor without putting the calipers back in. Ie anyone know of anywhere in central pa that rents trailors with winches? Can it be pushed up? Any flatbed trailor rentals around central pa anyone know about?
So to recap is it okay to fire up twice with a few bolts holding the vc down and reusing the same gasket?
And how would you recommend loading the car onto a trailor with no pads/calipers?
Thanks in advance for your help much appreciated.
i would not recommend starting the car with a valve cover half on... oil will probably spew everywhere. why dont you just play it safe an either bolt everything back on, OR just get a few strong people to push her up the trailer.. took me 3 people to get my car up the steep driveway i have, the car's not that heavy really.
Get you a come a long and a chain or cable that will be strong enough to handle the weight. You can also use it to help strap down the car.
It will be slow going getting it on as you will only be able to pull it up about 6-8 feet at a time then you have to pull the cable back out. It can be loaded with one guy this way too. I have done many A extra chain can be used if the car has no brakes, or if the tranny is still in the car, first can be used. Just check it before you completely unhook it as a car that comes loose while loading usually has alot of speed in reverse when it rolls off.
Harbor Freight has them for around 20 bucks for a 4000lb.
http://www.harborfreight.com/4000-lb...ler-30329.html
Dont forget straps to tie the car down too. I tow alot of cars and they like to move around if not strapped down right. I use a criss cross pattern to pull it the other way from where I mount it and check it any time I stop just to make sure its tight and no issues come up.
Make sure to center the load on the trailer. If you put too much weight on the front of the trailer (depending on the truck your towing with) it can cause it to lift the front end and make it hard to break or even walk around. Load it to heavy in the rear and it makes the trailer tail happy. You have a large room of adjustment on most trailers and move it around until the truck does not squat real bad or seems higher. I also prefer to have the car forward to keep the weight up front.
Very important is to check your trailer tire pressure. This is the difference in making the trip with out issues, or sitting on the side of the road or pulling a car on a 3 wheeled trailer.
Got any more questions, just let me know.
Come along ftw
Thats what I used to load my car up on the trailer while it was inop. Its really slow but one person can load it up on the trailer as well. For the price its a great solution.
get some husky tie down straps like these:
http://www.autozone.com/autozone/acc...er=155289_0_0_
Any trailer store or auto store should be able to help you!
I personally went to Home Depot. They had some REALLY beefy straps, I forgot what specs were but I just made sure and got the heaviest duty ones they had. One piece of advise, make sure and check the straps EVERYTIME you pull over at a rest stop, gas station, etc. I had one on the uhaul trailer that covers over the wheel start to come loose a bit. Luckily I caught it in time.
any trailer store or auto store should be able to help you!
