Ac compressor and fan question
Old Aug 10, 2012 | 06:01 AM
cky_bam_marg's Avatar
My compressor clutch isn't engaging even after replacing the compressor it still isn't engaging, i was wondering if the ac condenser fan isn't plugged in will it keep the clutch from engaging?
Is so where can I find the wiring harness with the ac condenser fan plugs? Mine where damaged from an accident?
It's been 104 degrees in Cali for the past few days and I need this problem solved ASAP :-(
Old Aug 11, 2012 | 03:04 PM
matrho2792's Avatar
I'm actually having the same problem myself. Make sure all the fuses and relays are still good as well. Hopefully someone can chime in on this soon.
Old Aug 11, 2012 | 03:54 PM
grim~'s Avatar
the condenser fan fuses are in the engine bay fuse box,they are both 30a fuses i believe.
The condenser should still work even with out the fan,mine did but it really only worked good on the highway because if your in stop and go traffic the condenser will become heatsoaked and just blow hot air,also its pretty dangerous to use it without a fan cause you can blow seals and then youll just have another problem on your hands.
jacked cobra
Jul 28, 2017 10:35 AM
lghtngyello03
10
Jul 22, 2016 04:26 PM
05EV08
May 11, 2016 03:58 PM
3bar_dc2
Feb 24, 2016 11:43 AM
Havoc86
Lancer Troubleshooting
Aug 14, 2012 10:29 PM
