2wd dyno tuning an Evo??
Road tune is not going to heat soak the intercooler and ensure safe timing while the car is on a race track for extended periods of time.
ha, no I am not selling the Autronic. Money is not an issue for me. I may end up shipping the car to NY. Email tune can never be as good as a car done on a dyno. Good luck finding MBT through email. I can make the A/F right myself and throw safe timing numbers at it, but that's not the point. Max horsepower doesn't do anything for me either, power under the curve does.
This is not my DD it once was, its a track toy, that I want to use to go play with the big boys in TTU.
Does your Stock ECU have the ability to log any user given parameter, at a user specified time, with a user specified number of data points? Can it data log the J&S SafeGuard Interceptor thats installed in my car? Does it have the ability to log the wideband? Does it have fail safes in place for loosing MAP sensor with the ability to still drive the car?
Its not that I need it, more like I want it.
I am in Southwest MI. Tuner is Bob Payton at Speed Lab, said to be one of the top tuners for Autronic in the Country. Mitch at AMS tuned the car prior, he has since left to work at COBB. This leaves me in search of a Certified Autronic tuner. Next closest besides Bob are in Virginia or NY.
Then why dont you just put a ****ty fmic on there that is super inefficient its the same thing. If your gonna road race your car, then heat soak isn't the answer. If your car is tuned by someone who can tune the car specifically for that, then it should be reliable. Heat soak has nothing to do with a tune being good or not. Heat soak just means your fmic is doing a ****ty job not keeping air temps cool enough and the car is losing power. That isn't a sign of a good tune. Being your car is in constant motion on the track the fmic wont heat soak. Well that is unless you put an ss auto chrome or some pos like that on there. Tuneing the car for mid boost level and responsiveness is the key, not heat soak my man.
DO NOT DO THE 2WD DYNO. Contact an etuners. Tscompusa will do it, and if he cannot there are others who can. Livernoise has a dynojet, Speed Industries has an old *** mustang, Pure Tuning has a dyno. There are 3 places you can get the car tuned or have someone tune it there and there all awd dynos.
Speed Industries collaborated with GodSpeed the same people that blew up my engine on the race track.
Pure I trust, however Keith has limited experience with Autronic. I spoke to him about it, he can do it. He also has experience with the J&S unit in the car. I am just looking for someone that knows the ECU inside and out.
If you guys are willing to take your car to just whoever that is fine by me. Heck I can tune your car for you if you want. However I want someone that is very credible with lots of experience tuning Autronic ECU's.
i've done my fair share of wot's, back to back to back, no issues at all.
car's been running great, tuned for 0 knock, everything just right.
What i like about road/email tunes is, its as real as it gets... road bumps, wind, all the conditions. On top of that, its very convenient to get my tune touched up when i add any mods since i dont have to go anywhere, just a nice open road to do couple wot pulls.
Livernois will be happy to swap your stock V8 for a crate motor. Don't trust them, I know someone that worked there.
For some people its great don't get me wrong. It may work for you perfect and get the results your looking for. As far as convenience you cant beat it. I am definitely not in a spot of any convenience. Driving the 3hrs to AMS was convenient enough for me. Back to back WOT is not the same as WOT for 20-30 minutes at a time.
They did this because I tell them the car is for road racing. The timing is more conservative as well. If you just drive your car on the street or drag race it, you will never put the stress on it that you do road racing. Your right, the fan can never simulate on the road. Yes the IC's will always heat soak if they continuously run it on the dyno. Most tuners that do normal cars allow the car to cool off before continuing to tune and do runs. This is to try and keep the IC/Engine at normal operating temperatures thus tuning the engine for max power where it will normally be temperature wise. Under extreme conditions of road racing you overheat everything. Trust me, cause if it can overheat I have done it.
