Front windows not rolling up issue
Old Aug 18, 2012 | 10:03 PM
eder-loco's Avatar
Im in need of some help, last night the front window switch started to take a dump both back windows would roll up as i clicked the button, but when i tried to press the front buttons for the front windows to roll up none of the front ones would roll up.
but if i pressed the button on the passenger side for the passenger side window to roll up it would.
So what i determined was that for some reason the two front buttons on the drivers side are not working but the two back buttons ones Do work
Any ideas? car is currently sitting in the garage as its raining outside and i was stuck on the freaking rain after i left the ATM with the window down
Old Aug 19, 2012 | 12:56 PM
dastallion951's Avatar
That sucks first thing to do is check passenger front window switch roll up n down the window. If so then pop the lf window switch on the door up, see if anything disconnected. If so buy a new driver window switch that comes with new buttons. Worse comes to worse might have to remove door panel which isnt hard . Fwiw my lf window made a pop noise then stopped workin, screws Fell out n window dropped slicing my regulator wires connector. Gl
Old Aug 19, 2012 | 03:13 PM
eder-loco's Avatar
Well i ended removing the door panel which was pretty simple, and i moved around some wires and plugged the connector harder in and its working just fine now.
still puzzles me as to why it didnt work last night but now it does by just moving around some wires.. mmm...
