EVO 9 idle issue
EVO 9 idle issue
I've been having this problem for quite sometime, like a year-ish. Basically my idle would go up and down here and there at a dead stop. Also coming to a stop, it will do the same thing.
Here is video I recorded, just bleeping throttle will also cause it to do it too.
Not sure if it's my MAF or IAC or some other sensor.
I've had the engine rebuilt 4-5 months ago and got it tuned 2 months ago. The car have no issue driving, I did a boost leak test and there isn't any leak at all (tested up to 25psi). Also there is no CEL.
Any idea what it could be.
IAC is what the video looks like but if that's not it.
Then it might also be a bad front 02 sensor. When in closed loop fuel trim operation (as it would be during idle) the front 02 is responsible for telling the ecu if its rich or lean. If the signal is skewed fuel could be added and leaned at the wrong reading, causing the idle to change.
Took out the IAC and tested it, it works as it should. Also swapped from another EVO, still have the same issue. I'll see if I can get the car logged, possibly see if there is something unusual.
FS[Northeast]: NY/RI 2006 Evo IX SE 77k miles
killerpenguin21
For Sale - Cars For Sale
27
Sep 17, 2017 02:57 PM
Clayton Kwok
Mar 15, 2017 02:12 AM
