starter click... still
Ok gurus, I will pay someone, anyone, who can figure out what the hell is going on with my car.. I'm still getting the "click" when trying to start the car periodically. It clicks once per turn of the key, not a fast continuous clicking.. Sometimes it will click 3 or 4 times (turn the key 3 or 4 times) then start, others it will click as many times as I turn the key and not start, let it sit for a while, then starts right up. Now before you think you have this figured out here's what I've done so far:
Replaced the starter 3 times (with 3 different starters)
replaced the ignition switch
replaced the ignition relay
added 2 additional grounds
checked the wiring between the relay and starter
Replaced the battery twice (voltage at or above 12.0)
charged the battery overnight
I'm very seriously considering just giving up and selling the damn thing at this point.. I need the stupid car to start, I can't be stranded or not able to get to work. This has been progressively getting worse over the past couple of months to the point where it won't start sometimes..
HELP!!!
HELP!!!
might have a stupid question for you....but perhaps the key itself is worn out...??? does your year have the chip in it by chance? If you have a spare key, try using that to rule out the issue. Ive been dealing with the pesky intermitten starter issue. Mines leaning towards the ignition switch where the key goes in. If it dont go in a certain way, doesnt work sometimes. I usually have to push mine in slightly or wiggle it a bit as im going from on to start. Good luck. Or if you have a turbo timer plugged in, id check the wiring from that to the starter column.
Sounds like your immobilizer is acting up have you tryed removing it from the ecu and see what happens from there if not you may have a poor connection some where between your switch and started. Also have you check the your neutral safety switch, which can cause this .you can bypass the also see if that help.
I have the immobilizer disabled in the Tephra options. It's been that way for some time. Now, there is an alarm installed (it was there when I bought the car). I'd have to pay someone to test that since I have NO idea on how to do that.
I'm not sure about the neutral safety switch? Where would I find that to test it?
As for the wiring, I verified that there is continuity all the way from the ignition switch to the relay and from the relay to the starter.
Great ideas!! The other thing I've read is something abuot the ring gear or flywheel possibly binding?? I checked the teeth on the flywheel when I had the starter off and they looked perfect. So I'm not sure that's the problem.
Any other thoughts??
